    Apr 2008
    Default replace garage door with a wall and double entry door
    i would like to replace my garage door with a exterior wall and double entry door, it is a two car garage, the garage floor is a few inches lower than slab of house, i do not want to level floor, just add a wall with a door, wondering how to seal or install frame so no water can leak in from driveway, seaps during hard rain and wind
    stephen
    Apr 2008
    Quitman , Ms
    16
    Default Re: replace garage door with a wall and double entry door
    Hello there . I'm not sure if this is true or not , but a friend of mine once told me that his homeowners insurance company gave him problems over this same situation . Because he " added a room " that was below the grade of the rest of the house . This may or may not be an issue with you but I thought I would mention it . Good luck .
    Apr 2008
    thanks for that, i will check into that
