    Apr 2008
    S.W. Pennsylvania
    0
    Angry Stair Railing Holes for the Ballesters
    Im trying to figure out what angle to use to drill holes in a stair railing Im replacing. My treads are 9.5" and my risers are 7 3/8" high. Is there any jig that I can purchase to make this easier? Or should I hire someone to install it?
    6,047
    Default Re: Stair Railing Holes for the Ballesters
    Easy way, lay your banister on the stairs, measure the angle between the riser and the banister. Then use the set angle gauge to set a drill press or the drill attachment that ASC2078 mentions.
