    Dec 2009
    Default Well head insulation
    What is the most efficient way to insulate a well head sitting 2 ft above ground. It is 100 ft from its storage tank inside of a heated, insulated closet inside a garage? I need serious suggestions.
    5,789
    Default Re: Well head insulation
    You shouldn't need to insulate if you have a pitless adapter installed below the the frost line. However, one of the easiest things to do is build a well house over the well head and install a light to keep it above freezing.
