    Default Tile Adapters For Gutters
    Hello, is there any way to connect the tile adapters to downspouts without cutting the downspouts. Just order couple of them and would like to install hopefully without cutting the downspouts. Any suggestions/tricks. Thank you
ID:	981   Click image for larger version.
    2,009
    Default Re: Tile Adapters For Gutters
    Lossen or remove the downspout & the reinstall.
    You may still have to cut off some. Snips should work.
