I remember an episode where your program went over updating a well system.
I belive the pump used was supmersed in the well shaft, but was digitaly controled, pump was either variable gallonage,and/or pressure. Which provides a constant pressure through out the home.
I currently have to update my system in Florida and desire to install the best possible system.
The well is approximately 150 feet from the home, previously the surface pump and tanks were moved away from the home. Current contractor feels tanks and surface need to be relocated back closer to the home to aid in creasing pressure.
Can not run any water fixture if someone is the shower.
Any information you can supply would be appreciated.
Thanks
