    Default Install new acrylic tub
    I am installing a new acrylic tub to replace an old one. The tub is on a slab floor.
    Should I use something under the tub? (Foam, thinset, etc...)
    I know I need plumbers putty around the drain, but do I use Teflon tape or pipe dope or anything on the threads of the drain in the bottom of the tub where it connects to the PVC drain line?
    Default Re: Install new acrylic tub
    You don't really need anything but tephlon tape never hurts.
