Results 1 to 7 of 7
    Apr 2008
    NC
    Default Slow hot water - kitchen faucet only
    I recently installed a new kitchen faucet and have had a slow hot water trickle ever since.* The cold works fine.* I removed the water line from the faucet and only got a trickle so it's not the faucet. I think the problem maybe at the shut off valve but have no idea how to go about fixing it.* A picture of what I'm working with is attached. Can you help an inexperienced "plumber"??
Name:	KITCHEN SINK SHUTOFF.jpg
    Sand Springs, OK
    467
    Default Re: Slow hot water - kitchen faucet only
    I think I would just replace that valve. Obviously something has gone wrong inside. When you take it off the other end maybe you'll see that something has simply slipped out of place but it's better to just get it out of the house and get a new one.
    Debby in Oklahoma
    Apr 2008
    NC
    Thanks! Any advice on how to replace it?
    Mineral deposits can sometimes greatly reduce water flow. These deposits can accumulate inside the faucet, the shutoff valve or inside the supply line. With hot water shutoff turned off, I would disconnect hot water supply hose at the shutoff valve. Use a mirror and flashlight to inspect opening. Use a wire to break up any mineral deposits. Also, inspect the water line that connects between the shutoff valve and faucet.
    Jim
    Apr 2008
    Worcester, Ma
    8
    The best thing to do with these valves is evr six months shut them off and then back on a few times. The rubber will get stuck to the valve bodies and then the vavle if useless when you need to shut the water off. Or back on in this case.
    Apr 2008
    NC
    Thanks! I will try these suggestions and see what happens!
    Apr 2008
    Detroit, MI USA
    Quote Originally Posted by atea View Post
    Jim
    I know with my galvanized, when I've replaced sections it would knock loose the accumulated rust inside and it doesn't much to block an opening.
    That's why as future sections start to 'fail' I'm going to replace with copper.
    What I want is a celebration
