    Apr 2008
    Question Help in the bathroom !
    I pulled out my old vanity and there is a heat vent underneath. There was a makeshift wooden duct directing the heat to the front of the vanity and a hole cut in the kick plate. The box is broken and too high for the new vanity (5 inch clearance). It looks like this: "[IMG]value[/IMG]".
    What can I use to create a duct to direct the heat?
ID:	962   Click image for larger version.
    Sand Springs, OK
    467
    Default Re: Help in the bathroom !
    You can either build another one with smaller dimensions or look for a metal one.
    I have the same configuration in my guest bath and under the kitchen sink.
    Debby in Oklahoma
    Apr 2008
    Binghamton, NY
    20
    I would build one personally, seems like a simple enough task.
    New homeowner in need of Hidden Content assistance.
    6,103
    That's pretty common in remodels. As small as that vanity is you may be able to just cut a vent in the front kick plate.
