Results 1 to 9 of 9
    Oct 2007
    Louisiana (Cajun Country USA)
    146
    Default Older Style Rotary Phone...anyone have one?
    Does anyone out there have an older style rotary phone like the one pictured here that they might be willing to part with? I'm looking to replace a part on the one I have.
    peace,
    Sophie
    42
    Default Re: Older Style Rotary Phone...anyone have one?
    If nothing turns up here , try EBAY . BTW , what part do you need ?
    6,074
    You might try some locale antique shops or flea markets, I seen a few pop up there.
    Oct 2007
    146
    Quote Originally Posted by WitchDoctor View Post
    The jack that the phone line plugs into at the back of the phone. The lip edge that goes around the jack to keep it from slipping inside the phone case has broken. In addition to that, the jack itself has cracked in half. I tried gluing it back together, but it just won't hold. I've checked EBAY a few times, but am not willing to pay so much for them. I should probably keep checking every so often. I may get lucky.
    I've checked with a few...no luck so far.
    peace,
    Sophie
    6,074
    Sophie is this in your price range http://www.rotarydialphones.com/black500new.htm or for parts you might try http://www.oldphoneman.com/Parts50s70sphones.htm
    Sounds like it's just the female RJ 11/12 modular jack that may need replacing.
    The pictures are just examples and not the exact ones that would fit.
ID:	960   Click image for larger version.
    Oct 2007
    146
    ***! New and never used. Looks great, but I can't justify spending the $70 when the phone I have works just fine....except for the jack slipping inside the case.
    I found what I needed from a Canadian company. This is it....
    http://www.oldphoneworks.com/antique...&PhonePart=595
    Edit: On second thought, that may not be right. That is for the handset. I need the back jack. I did email them a question about it, so we'll see.
    peace,
    Sophie
    They have the part listed.
    http://www.oldphoneworks.com/antique...nePartType=100
    Good luck.
    Oct 2007
    146
    Good luck.
    Yes, I saw it after I posted and after I had edited my post. Didn't want to edit again!
    peace,
    Sophie
