    Apr 2008
    Default attic insulation
    My son bought a 1950s ranch. Above the ceiling (stapled in cardboard like tiles) and furring strips the attic has some kind of black fabric like paper (different from roofing felt) then a layer of 3+/- in. fiberglass insulation with the facing on top and a layer of blown in cellulose to the top of the 2x6s. I know the fiberglass should not have been installed with the craftpaper up, here in VT. The walls in the house are 8'. We are thinking of installing a new sheetrock ceiling below the existing cardboard like tiles with 4 mil poly above the sheetrock as a moisture barrier. I can't feel any moisture in the insulation except where there is a known leak at some roof flashing. We are planning to add an additional 12" of insulation. Is this workable or will it cause problems that I am not aware of.
    Lakeland ,MN
    356
    Default Re: attic insulation
    I would assume that because of the tar paper and the craft paper side up there might have been a previous moisture problem. If the moisture problem returns you then you open yourself up for mold. That could be a real problem.... In my opinionI would fix what is wrong first then drywall.
    Apr 2008
    Quote Originally Posted by Ravens53 View Post
    No apparent moisture problems not related to actual roof leaks. Kind of tough to dig out 6 inches of insulation consisting of about 3 in each of upsidedown craft faced fiberglass and blown in celulose in a 26x46 6 pitch attic. Anyone have a giant vaccum? What about using a long tined rake in each bay to shred the craft paper between the 2 insulating materiels.
