Thread: porch issues
    Apr 2008
    6
    Question porch issues
    What is the best and cheapest solution for a porch with that plastic carpet stuff glued on it once the carpet gets torn and it won't stretch back in place to be glued again. We would actually like to get rid of the carpet look on our front porch. What is the easiest way to remove it and how do we repair the cement with old glue all over it after the carpet is gone?
ID:	935   Click image for larger version.
    Sand Springs, OK
    467
    Default Re: porch issues
    There are adhesive removers, sc****rs and cement grinders that will get rid of the left over glue.
    Afterward, I would add step safety paint to the surface if you don't like the color of the concrete. This paint has grit in it to make it rough.
    Debby in Oklahoma
    Apr 2008
    6
    Thanks Debbie! I'll look for those things.
