Results 1 to 8 of 8
    Default Cementing a Fence Post
    Hi,
    Last year I had a fence installed. The posts were not cemented. Now a few of the posts are leaning. Is it a good idea to cement them in before the situation becomes worse?
    The deep South
    459
    Default Re: Cementing a Fence Post
    That subject comes up around here every now and again , with varied opinions . I vote for concrete . It's always worked well for me .
    Apr 2008
    Worcester, Ma
    8
    Im installing a wood fence in my yard next week. I am useing cement but I was told to use a roof sealer in the area being cemented , to slow rot. I see to many fences around here with leaning posts, not what I want in my yard.
    8,065
    Quote Originally Posted by muck View Post
    If you want a permanent fence, then don't use wood posts. Use steel Post Master posts instead. They are virtually invisible after the fence is built.
    [IMG]http://www.fence******.com/architects/images/postmaster-main.jpg[/IMG]
    Apr 2008
    Worcester, Ma
    8
    Thats very nice I like that, Im gonna look into that a little further. Thanks for the picture.
    8,065
    You should be able to find them at any fencing dealer. Evil Orange used to carry a similar styled post, but I've not seen them there in a while.
    Question Re: Cementing a Fence Post
    A section of my fence and gate with cedar posts in concrete was snapped off at ground level during the recent Ike inland storm here in St. Louis. Could this kind of post be used in the concrete base from a previous post? Is it narrower than an orignal post therefore allowing it to be reinserted in the concrete "hole" left and then additional concrete poured around it to fill in the expanse left behind by the original post? Digging out the original concrete would be difficult since it is up against the side of the house and a retaining wall area.
    8,065
    Quote Originally Posted by riveresk View Post
    You might be able to get away with that, as the Postmaster style post is narrower than a standard 4x4 post, however, these posts are not as rigid as a wood post, so they will flex if a gate is hung on it. This isn't necessarily a problem if the gate is in the middle of a run, but as a corner post with a gate attached, it's going to flex to the point that the gate may not operate properly. In this instance I would recommend using a pressure treated 4x4 in a new concrete base, which means pulling the old core.
