Thread: level pool
    Question level pool
    Im installing a small above ground swimming pool(15'x4')in my back yard.How do i level the area that it will sit on?
    Sand Springs, OK
    467
    Default Re: level pool
    The pool we had at another house sat on a bed of good grade sand.
    My husband said his father had box blade back in there flattening the spot and clearing it from debris, then he raked it to make sure all the rocks and limbs were really gone, then he put down the sand. He didn't attempt to really level it knowing that the liner of the pool would find a good level and push the sand around to make the curve on the bottom as it wanted.
    Debby in Oklahoma
    612
    A long, long time ago we leveled the area for out above ground pool by doing the following:
    - drive a steel rod in the center of the area
    - find a "true" and straight 2x6
    - drill a hole through the "6" part of the 2x6 and slide it over the rod
    - put a 4'level on the 2x6 and rotate it around the area leveling the sand as you go.
    Sand Springs, OK
    467
    Quote Originally Posted by bp21901 View Post
    oh now that sounds like a much easier way to do it than I described.
    Debby in Oklahoma
    612
    Leveling the sand was the easy part, roto-tilling and shoveling out a couple inches of dirt and raking out any stones was the extremely hard part!
