    Default Glass Bock Installation
    How do we install glass block partiation wall 5 block high 8 block long?
    Sand Springs, OK
    467
    Default Re: Glass Bock Installation
    make sure the opening is level and square then you use mortar that is rated for glass block. They even have spacers specifically for glass block to keep the grout lines straight and pretty. I saw an article in ATOH where Tom says it could be stacked with silicone too but I think there's an insert that goes in the groove before hand. The article was about hanging a towel warmer in a glass block wall.
    or you could investigate a system like this. http://www.ibpglassblock.com/
    Debby in Oklahoma
    5,987
