    Exclamation Custom Molding Machine?
    I recently saw on TOH when they were milling custom trim and molding after getting a couple of blades cut with the profile. Can anyone tell me where you can buy these machines or what they are called? Or is it going to be cheaper for me to go to a lumber yard and have them cut it themselves (I have a whole house to do in trim about 2500 sqft) thanks for help
    5,797
    Default Re: Custom Molding Machine?
    Here's the machine they used http://www.williamsnhussey.com/Merch...Store_Code=WNH
    There are other brands like http://www.woodmastertools.com/s/molding.cfm
    Set up and run charges can be rather high in some custom shops if you need custom trim. If it's standard molding the machine will probably not pay for it's self on just this one job.
    Upstate NY
    34
    W & H will cost about $2,000. Unless you add on options.
