The slot configuration tell you if it is a 15 amp or 20 amp outlet not the price
</IMG>20 amp outlet
15 amp out let
The price usually tells you the material used for the contacts are heaver, which means more plugging and unplugging before failure. And that the material used for the stab connectors are heavier. However I never use the stab connectors.
