    Default cleaning shower temperture control valve
    Rich did a show a while ago where he replaced a shower temp control for someone and then told them sometimes you can just clean them to stop the drip. I have replaced one before but would like to try to clean it first to see if it will stop the drip. My question is when I do go to clean it, should I use something like CLR or Lime-away?
    Herb
    Default Re: cleaning shower temperture control valve
    Thanks Yuk Yuk I guess it is the same as cleaning the coffee maker. I will give that a try.
