    Default Any ideas on laminate coutertops
    First time installing counter tops and I'm not sure how to bend the edges around a corner. any hints!?
    Sand Springs, OK
    467
    Default Re: Any ideas on laminate coutertops
    heat it up. Not too hot but it will be pliable enough to bend with a little heat and a lot of pressure.
    Debby in Oklahoma
    Quote Originally Posted by debbysewn View Post
    Thanks debbiesewn. Do you think that and iron will work and if so do you heat it with the glue on or preform it?
    Denver, CO
    666
    Me thinks you are asking for a nightmare of a project if you try and bend your laminate.
    You will have a much easier time of it by either banding the edge with laminate or going with a wood band for the edge.
    Here's a work top I made for my office with an oak/stained edge.
    Man! I gotta clean this place up!
    Sand Springs, OK
    467
    Quote Originally Posted by seanttracy View Post
    I was thinking about a heat gun or hair dryer but I think an iron through a cloth would work too, start at a middle setting and work you way up if you don't see any results.
    Yes, put the adhesive on first.
    Debby in Oklahoma
    It is very difficult to post form (bend ) laminate, particularly if you don't have the right one. Laminate comes in different thicknesses. There will be no way to post form the thick stuff and you'll have varying results with the thin, depending on the radius you're trying to accomplish. You'd be better off installing a wood nosing and routing a radius than you will trying to bend laminate around the same corner.
    Sorry, not what you wanted to hear, but this is what experience has shown.
    1,131
    How easy or how difficult this might be will depend upon how tight of a radius you're attempting to turn with your laminate.......and whether you'll be using horizontal or vertical grade laminate. (The veritcal grade will bend easier than the horizontal grade.)
    If the radius is 3" or greater, you shouldn't have much a problem at all, although some heating of the material may still be advisable/desirable as you approach 3". Maybe, maybe not. It depends upon the material. A little quick trial and error experimenting will guide you.
    If you're trying to bend to a tight radius such as 1 1/2" - 2", then heating will be necessary. You can use a heat gun and a heavy leather glove to pre-bend/form the laminate. Most common plastic laminates (such as Formica & Wilsonart brands) will bend easily/best at around 325 - 350 F. Carefully coax the material up to temp with the heat gun and bend the material right around the edge it's to be attached to......and then allow it to cool in place. Then apply your contact cement and lay it. Or you can use PVA glue for this, but you'll likely find the contact cement to be handier because it grabs instantly and no clamping is required.
    If this is the edgebanding on a countertop you could cement the most of the straight run to within say a foot of the corner and then do your heating, bending and gluing of the cornerand the remaining straight end/side. Or you can clamp/secure (double-stick carpet tape) the straight run in a temporary fashion, do the corner bending and then cement the whole piece at once.
    If you overheat the laminate, you can ruin it. There are temperature "revealing" markers that can be very helpful. Your laminate supplier may have these on hand......or maybe not.
    http://www.airgas.com/browse/product...381&WT.svl=381
    I suspect/ hope you know that you'll want to attach your edgebanding first, then remove/trim the protruding excess so it is dead flush with the top and bottom edge.....and then apply the laminate on the top of the counter.
    I am not a big fan of water-based contact cements. They have a tendency to dry out and let go of the laminate after a couple/few years....particularly near the edges. I use solvent based adhesive. Much ventilation is a MUST !!! when using solvent-based contact cement.
    1" radius bends on edgebanding are *possible* by hand, but require more experience and caution. If you intend to attempt such a thing, plan on doing a few trial runs first to get your techniques down pat before approaching the real deal. Don't be surprised if you fail on that tight of a radius. There are reasons that countertops with bends that tight are ordered from manufacturers who have the specialized equipement to pull this off with efficiency.
