    Sep 2009
    23
    Default pipe insulation against wall
    im trying to insulate my hot water pipes in my crawl space and have run into a bit of a snag. my pipes are so close to the wall i can not get the pipe insulation tube behind it. would a spray on type insulation work?
    erika newark de usa
    Default Re: pipe insulation against wall
    Can you undo the hangers and isulate then rehang the pipe? Spray on insulation is not the answer.
    Plumbing and Heating Tech.
    My plumbing website Hidden Content
