Page 1 of 3 123 LastLast
Results 1 to 10 of 27
    27
    Default Main Circuit Breaker Voltage Reading
    I tested the voltage of the two main hot wires going into my main circuit breaker (the circuit breaker was off). The voltage read 124V on each. I then turned the circuit breaker on and re-tested the voltage. One wire tested at 0V and the other tested at 122V. Does this mean I have a bad main circuit breaker?
    The deep South
    459
    Default Re: Main Circuit Breaker Voltage Reading
    Did you read 0 volts on the load side of the breaker ?
    If you did , " excercise " the breaker a couple of times and recheck . Make sure all connections are tight ( use extreme caution ) .
    27
    I don't know what you mean by load side of breaker. I will go take a picture.
    27
    Here is the picture. Do you see where it says "MAIN" it has two wires. I tested each wire. When I went back to take the picture I tested it again. The wire on the left read 60V and the wire on the right read 122V.
    The deep South
    459
    That looks like the wires coming from the meter base . Possibly a bad connection in there or anywhere back to the transformer secondary . If everything is clean and tight in the breaker box , then it's time to backtrack . That will involve an electrician and possibly your power company. I would start with the power company . They won't charge you for checking out their connections .
    What started this investigation ?
    27
    Thanks! Another question, should it be reading 120V on both sides? Is it possible the breaker is bad? Is it possible one side of a breaker can go bad?
    27
    What prompted the investigation? Last night I lost power to certain parts of my house and outlets. Occasionally the power would come back on and then go off again. None of the breakers were tripped.
    The deep South
    459
    Yes , one side of a 2 pole breaker can fail . Are you losing the voltage on the LOAD side of the breaker or on the incoming wires ? Big difference .
    27
    I believe its what you call the load side. Here's a better description.
    Ok guys, here is a picture of what I am working with. I think I know what's wrong. I am only touching the breaker that says "main" in the photo. Do you see those two screws on the breaker that says "main"? That's where I am taking my voltage measurements using a multimeter.
    Scenario 1: "main" breaker is set to "off" position. I put one multimeter lead on a ground and the other on the left side screw of the "main" breaker. Multimeter reads 120V. Next I put one multimeter lead on a ground and the other on the right side screw of the "main" breaker. Multimeter reads 120V.
    Scenario 2: "main" breaker is set to "on" position. I put one multimeter lead on a ground and the other on the left side screw of the "main" breaker. Multimeter reads 4V. Next I put one multimeter lead on a ground and the other on the right side screw of the "main" breaker. Multimeter reads 120V.
    The deep South
    459
    Check your PM box .
