Thread: Liquid sander
    21
    Question Liquid sander
    Has anyone had success with a liquid sander. I need to paint over all of my gumwood trim that has the original poly,shellac (or whatever coating that was used) on it. I have seen the liquid sander in the store and it looks like it would be so much easier than sanding the entire second floor of trim. Does it work? Will the paint adhere to it? Any input greatly appreciated. Need to sell this house and move to be with elderly parents and time is of the essence.
    64
    Default Re: Liquid sander
    A $3 sanding sponge would probably do the job faster and cleaner than worrying about dripping that stuff where you don't want it. You don't need to sand down to bare wood, you just need to take the shine off so the paint can grip.
    1,131
    When you say "will the paint adhere to it"...do you really mean paint......or do you mean that you'd be appplying another layer of clear-coat finish?
    Which one...will make a huge difference as to what prepping approaches will/might work and won't work.
    Yes, I use deglossers and very successfully. No failures to date with paint peeling later on. The best one that I've found is the deglosser sold by Sherwin-Williams. It is HOT stuff. Meaning........it will soften the underlying layer in very short order (5 - 10 seconds)with no rubbing involved. Wipe it on and leave it alone. Cloth damp, not wringing/dripping wet. Cloth...not paper towels is my recommendation. Don't play around rubbing the surface after the liquid is on as the paint will soften enough that it can be pushed around and smeared.
    The deglossers sold under the name Savogran are not nearly as hot and will require some rubbing. They never do degloss as well as the SW product, although they seem to do adequately as the paint as never peeled on me when using it. It's just way more work.
    Of course, you do not degloss way ahead of yourself/not anymore than you can paint within say 30 minutes.
    Depending upon what you have for an exisiting finish (shellac, lacquer, varnish, poly, etc) .........you will likely have adjust your deglosser application technique accordingly. If poly or another type of varnish, a lackadaisical approach will serve okay. If shellac or nitro-lacquer, it will likely melt so fast under the deglosser that you could end up actually removing it if you don't play soft and gentle with your hand and that cloth.
    Are you sure you actually want to paint that woodwork? Once covered in paint it will be ten times more work for someone to return to the wood. Often that extra work/money is the deal-breaker,so to speak, and the house never gets returned to its original appearance. For some houses, that's okay. For others...it's a cryin' shame.
