Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
  1. #21
    Shamokin, Pa.
    645
    Default Re: Power Strip installation?
    Are they NEC approved?
    Per 2005 NEC, methinks.
  2. #22
    6,080
    One thing I forgot to mention was that power strips (actually called relocatable power taps) do not fall under the purview of the NEC to find out which ones are approved for the insulation in counter tops you would have to check Underwriters Laboratory White Book. Something else for you to read.
  3. #23
    Lakeland ,MN
    356
    Jack I agree on the UL listed assemblies. But keep in mind a inspector does not inspect a UL listed assembly. But the he can turn down it being used. It must be listed for that USE. Key word is for that USE. And I am not sure if a power strip in a kitchen of all places would be approved unless it was 20 amp rated. Just my opinion. I hate power strips or extention cords as they to me are fires waiting to happen..
  4. #24
    6,080
    Raven,
    There are a few power strips approved for in counter kitchen use at UL. I don't have their White Book so I can't list specifics. Yes it would have to be 20 amp rated but the discussion was about what size wires are needed in the strip to get that rating.
  5. #25
    Lakeland ,MN
    356
    Co0l Jack You Da Man!!!!
  6. #26
    Chicago, IL
    162
    Wiremold's line of Plugmold is what's needed here. I used to install a lot of this in store fixtures (lamp displays, etc.) It comes in a couple of different plug spacings (6" & 12" o.c. are the ones I'm familiar with, though there may be others.) It is available in 12-ga 1-circuit or 2-circuit varieties. It's also a pain in the a$$ to work with. Definitely buy the Wiremold wire connectors. You'll never get 3-4 wire nuts connected and still get the cover snapped on.
    HTH
    Dave
  7. #27
    6,080
    Quote Originally Posted by Dave357 View Post
    But is it UL approved for this application?
  8. #28
    Chicago, IL
    162
    Plugmold is wired with 12-ga wire, it is grounded, and it carries a UL label. I can't imagine why it wouldn't be approved for kitchen countertop outlets, but I'll leave it to someone else to go digging through the UL White Book.
    Jack, do you actually look up every switch, outlet, device, motor, appliance, fixture, doo-dad, etc before you install them?
    HTH
    Dave
  9. #29
    6,080
    No, most are used often enough to know they are approved, but when faced with a new application it is cheaper to check than it is to get Red Tagged and have to tear it out and replace. You have to deal with more than one standard, NEC, local code, UL certification, transmission standards, panel wiring and industrial standards. As one state inspector once told me "We don't give a damn what the national code is, this is what we require". Not knowing can cost a great deal of money. Power strips have been around for a long time but until recently were restricted by code to temporary use only.
