    12
    Default toilet drain to vent pipe distance
    I'm plumbing in a new bathroom (toilet/sink/shower). This bathroom backs up to an existing bath so most of my plumbing is pretty clustered. I have the sink going up a 1-1/2 inch vent and the shower with a 1-1/2 inch vent with the drain headed towards the toilet.
    My question is: The new toilet is using a 4 inch drain and is 7 feet away from the the main vent stack which is also 4 inches in diameter. Is this vent sufficient or is it necessary to get a smaller vent closer to the new toilet drain?
    My book says that with a 4 inch drain, the max distance to the vent is 10 feet, but I'm trying to make doubly sure as a 2 inch vent would end up swiss cheesing the (non-load bearing) 2x4 wall that separates the 2 bathrooms.
    Thanks inadvance for yer help.
    Jan 2009
    Default Re: toilet drain to vent pipe distance
    Hello,
    I am also in a similar situation. My wife wants to relocate a shower and swap locations of the sink and toilet. Can I reuse the existing vent pipe? The vent pipe now handles all 3 fixtures, and is located right off the toilet. Currently, the sink and shower drain past the toilet.
    Thanks!
    Dec 2008
    Midwest
    174
    If you are reading the Uniform Plumbing Code I think what you are refering to 10' is the max distance of a 4" trap arm. The max allowable distance from a toilet to it's vent opening is 6'
    Depending on waht code you are using. The International Residential code states that you can put in a studer (quick) vent as long as you have a stack vent going through the roof some where in the house. Hope this helps
