Results 1 to 8 of 8
    41
    Default Sewer Gas Vent Pipe Disconnected
    While inventorying what needs to be done in my new attic (per Tom Silva's remarks on a TOH episode) before adding insulation, I noticed that the sewer gas vent pipe arising from the bathroom does not proceed through the roof, but ends about a foot above the attic floor. The pipe which runs through the roof drops down and sits almost but not quite square on top, about an inch or inch and a half offset. There is a metal clamp sitting at the top of the lower pipe, clamped to it alone, as though someone tried to make the clamp bridge these two pipes and failed. My plumbing skills stop at replacing washers. Clearly the pipes need to be connected, How do I do this or must I contact a Real Plumber? Thank you for your insights! best, M.
    6,080
    Default Re: Sewer Gas Vent Pipe Disconnected
    Use a flexable pipe connector It's a rubber tube with 2 clamps. Measure the diamater of the pipe and get one from Homedepot, Lowes, hardware stor etc. Seperate the pipes and slide it up on the top pipe, align them as best you can and slid it down on the lower pipe. Tighten the clamps and you're good to go.
    Nashville, TN
    148
    I agree with JLMCDANIEL completly. You will need a nut driver or a screwdriver (those 5-in-1 are the best for $5.99)to tighten it. The brand name is Fernco and the technical name is elestomeric coupling. But, just call it a flexiable connector. It will probably be 2" but do measure it. If you are mechanically able, you can do this. Good luck. Process of elimation.
    41
    Oh, thank you so much! I'm at the library and will print off your replies so I don't screw up. The guy at one builders' supply here in town suggested I fiberglass it -- as my rig is held together with fiberglass and Bondo at least I'm a whiz with those materials, but this is obviously so much better! I'll get the hired muscle to lift the upper pipe, as the entire affair seems to be Quite Substantial. Thank you so much! Nothing like somebody who knows what they're talking about. best, M
    6,080
    Instead of lifting try to pull the two pipes apart enough to get the collar on th upper pipe.
    41
    I personally can't budge that puppy. Cast iron, maybe? But who ever supplies the muscle, I'll certainly pass along your suggestion. Thanks again, best, M.
    41
    Say, I had the plumber Bob out for a look -- apparently when the previous owners were putting in new bathroom flooring and temporarily disconnected the toilet, the sewer gas vent stack actually was moved a bit in the wall, which is why it apparently sprang apart in the attic. There are two connections up there, both of which need the correct couplers. The upper stack is fine, but the lower part will have to be gently nudged into the correct place and shimmed. The upper stack will have to be lifted in order to replace the couplings, but this will not be hard I'm told, though it does include going up on the roof twice: to gently slit around the caulk between stack and jack, and then to replace that caulk. Now I am curious about nudging the stack without screwing up the connection to the rest of the plumbing. Before I bought my sweet home, I had no idea how totally ignorant I evidently am. Thank you all, again, so much. best, M.
    41
    Thanks again, everyone. Bob has come and gone, all is aligned and connected properly. I was dead wrong: it was the roofers, says Bob, who nudged the upper portion of the vent stack and it popped the connection. No worries to other bits of plumbing. He took time while on the roof to reinforce caulk on all the vent stacks. Now on to the water-damaged (washer flood) laundry room floor...best, M
