Results 1 to 1 of 1
    Dec 2009
    Default low flow toliet not flushing
    I installed a new low flow toliet in a basement where the floor is not level ( front to back) side to side is ok.
    Looking for ideas.
    I have tried leveling the toliet. It takes about 1/2" in front to level. It will flush once with some blow back but once I tighten the bolts it won't flush again. it seems to be very particular with being level. I have never had this issue with others I have installed in the past. I am going to take a different toliet from another bathroom and see if that will fix the issue. Any other ideas?
