    Oct 2007
    16
    Default Direct vent furnace
    Our house has a direct vent furnace that vebnts to the outside of the house through the foundation. The outside vent is covered with a 4in x 4in plastic louvered vent cover. The problem I have is, between the cold weather, and warm exhaust air, the plastic becomes brittle and the louvers break off leaving a hole into the house. I can not find any other covers other that the plastic ones at Home Depot.
    Does anyone have any suggestions
    Default Re: Direct vent furnace
    If you can't locate metal vents at a supply center then contact a heating contractor .... they should be able to hook you up with a nice sturdy gage metal one .... they don't necessarily have to have a damper or louvers.
    Hope this helps.
