    Dec 2009
    Default Acrylic vs Vikrell
    I am installing 2 bathrooms, 400 feet from Atlatic Ocean in a second floor condo that is on pilings so there is some movement. I will either use a Sterling 60X30 All Pro Vikrell tub and a Sterling Vikrell 48x36 center drain showe base.
    My secod choice would be a Lasco # AIS 60x30 Acrylic tub and a Maax center drain acrylic shower base. Either choice would be installed in the recommended base of mortar or Structolite. The walls amd floors will be tiled to a cement type backer board. Has anyone out there used any of these products and or make any recommendations or suggestions? Robert H
    Dec 2009
    Default Re: Acrylic vs Vikrell
    from the base standpoint its a personal choice.
