    Dec 2009
    Question Light Switch Outlet, which is the ground wire?
    I'm installing a motion sensor in place of an existing light switch. The old light switch had 2 black wires and the motion sensor has 2 black wires, but the motion sensor also has a green ground wire. Which wire in the outlet box does this green ground wire attach to? Is it the bare copper wire?
    Feb 2009
    693
    Default Re: Light Switch Outlet, which is the ground wire?
    Quote Originally Posted by rhplanter View Post
    Yup, the bare copper wire.
    Dec 2009
    Smile Re: Light Switch Outlet, which is the ground wire?
    Thanks-thought so, but don't wanted to be sure.
    Feb 2009
    693
    You should be good to go rh...........
