    Nov 2008
    Default bleaching burn marks
    After 40 years, I finally left the screen open. Now I have a silver dollar (2 inch) burn on the Oak floor. I used a circular sander to get the char off, but stopped before I dug to deep a hole. I really do not want to use a vibrating sander to finish and blend the depression into the rest of the floor.
    Does anyone have any experience in using a strong bleach such as Oxalic acid to bleach the remaining scorch marks out? Is there any other solution other then sanding or cutting a patch out of the floor?
    Please Help!
    Feb 2009
    Default Re: bleaching burn marks
    Maybe just cut in a Dutchman and sand smooth. Some flooring, a decent table saw and a good sharp chisel and you can make it flat again. Even if it does require a bit of sanding........... You can always say..... Remember when........
