Page 1 of 8 123 ... LastLast
Results 1 to 10 of 72
    Default Knob & Tube Wiring
    How dangerous is Knob & Tube Wiring to be left in a house? How does an electrician remove all old knob & tube wiring, in an existing lived in house?
    6,101
    Default Re: Knob & Tube Wiring
    It is generally very old wiring, and the insulation is dried out and starting to crumble. It is dependent on air circulation around it for heat dissipation ,so you can't insulate.
    Normally the electrician disconnects the wires from power, cuts some off but leaves most in place when rewiring.
    Shamokin, Pa.
    645
    In central Pa, you will find houses having K & T wiring, and blown in insulation covering the wire. i just shake my head
    Nashville, TN
    148
    it is not used anymore for safety and installation reasons. it caused fires. And there are better materials for instalatin now. When the electrician runs new wiring, and this is a must to meet code, you can salvage the old knobs and find other uses for them. it is a pretty cool piece of history of that house. Good luck. Proccess of elimination.
    Sand Springs, OK
    467
    I just watched the east Boston project episode again. The master electrician there said they needed to replace that knob and tube wiring for insulation purposes. I'm guessing he wanted to meet some other requirements too, like code and energy efficiency. Looks like K&T is out for good reason.
    Debby in Oklahoma
    Shamokin, Pa.
    645
    Quote Originally Posted by debbysewn View Post
    Lacking a proper ground path and air splices were the two main reasons that made K & T obsolete, would be my guess. And add in wire vastly undersized for todays needs as well.
    Sand Springs, OK
    467
    Quote Originally Posted by Ernie_Fergler View Post
    Lacking a proper ground path ...add in wire vastly undersized for todays needs as well.
    That would get my vote for replacement, not being grounded and not able to give me the power I needed.
    Debby in Oklahoma
    Shamokin, Pa.
    645
    Let us remember if the K & T was installed say back around 1920, to pick a year out of the air. Well what exactly did a then homeowner have to energize back then? A radio and a lamp.
    Sand Springs, OK
    467
    Good point.
    Debby in Oklahoma
    Shamokin, Pa.
    645
    Good point.
    How did they survive?
