Thread: main water leak
    Default main water leak
    I have a very small water leak in the main water line to my house. It's really a drip. Any suggestions on repairs?
    13
    Default Re: main water leak
    Where is it? If its before it actually gets to your meter it may be the water company's problem. Otherwise, whats causing it? Is it a leaky valve? or a joint? What kind of piping do you have?
    1,131
    Inside the house or outside?
    House-side or street-side of the meter/main shut off valve?
    At a joint or in the middle of a span?
    Type of pipe?
    Pic?
