    Default Black on outside of hot water tank
    The outside of my hot water tank is black above the opening to the pilot light. I have cleaned it off, but the black soot keeps on returning. How can I fix this and what is causing it?
    Default Re: Black on outside of hot water tank
    If it has any age on it it may be time for a new one the soot is from flame role out-you could have blocked flue or poorly vented flue-or you could have a bad valve or misadjusted gas pressure.
    If it new it may be set up for LP but you may have natural gas or vise versa
    If it is 10-15 years old it might be safer and more to your advantage to scrap it
