    Question Newton House - Teak countertop
    I just saw the episode that featured the teak end-grain counter top, that was sweet. I've made numerous butcher block cutting boards out of maple, but I was curious if any one had some suggestions for replicating the teak counter top. I would imagine the majority of the countertop would be 3" thick with an apron 4-5" thick. I would mount the entire thing on a double layer of plywood (making up the difference in thickness between the field and the apron). The teak blocks looked roughly 1 3/4" x 3" and then turned on end. I imagine using Resourcinol, but is there a cheaper route (epoxy based perhaps)? I would probably use some splines during glue-up to ensure alignment, and then I'd probably take it somewhere that had a wide belt sander and give it a level top prior to install. Any other suggestions?
    Thanks in advance
    Sand Springs, OK
    467
    Default Re: Newton House - Teak countertop
    I really think that counter top was that thick throughout.
    I wouldn't know about adhesives. I would imagine any waterproof and food safe adhesive would work.
    I liked the look too. I just don't have the router that would handle the tough wood.
    Debby in Oklahoma
    5,942
    I would imagine that after you glue up a row, you'll need to joint it before you try to glue it to another row. Even with splines there would be no guarantee of perfect alignment.
