    Dec 2009
    Default Going away in Winter.
    HI!
    We live in NewEngland and have bought our home last year, we have planned a trip for three weeks in January. I am looking for advice on what all things I need to do before leaving to make sure everything is fine while we are away.
    Appreciate your time and comments on this issue.
    Thanks.
    aBAJ
    Dec 2009
    Casper, Wyoming
    159
    Default Re: Going away in Winter.
    Don't turn your heat too low because your pipes cold freeze. If you have a programmable thermostat,you could set it to go on and off at certain times. Set your lights on timers, have a neighbor take in your mail and keep an eye on your home.
    ______
    Networx.com
    We provide the latest information on how to fix, renovate, and decorate your house using the least amount of resources for the best value.
    1,387
    Howdy consider turning off the water at your water meter if it is in your home so if any plumbing failure the water damage is slight. or at least the shut offs to the washing machine.
