    Default old house, new metal shingle roof, new water problems
    We live in a reasonably heavy winter snowfall area in an 1850s 3-storey house with a very steep main roof and valleys where later, lower additions join. This summer we replaced a very old, ratty but still functional standing seam metal roof with beautiful new stone-covered metal "cedar shake" shingles from Deccra; the work was done by experienced, reputable metal roofers who have worked with this product before. (We’re not house-handy people, so we try to hire professionals to help keep our old house in decent shape, and we thought we were doing the right thing to avoid water damage by replacing the old metal roof which was beginning to look ready to fail in places.)
    After living in this house for 17 years without a problem, now, after every snowfall and for weeks later, even when no snow remains on the roof, we have a brand-new problem of water steadily coming through in at least two places: one attic valley where it runs down an inside beam of an addition-roof, and one attic knee-wall where it finds its way into a second-story window frame and has damaged the wall in that room and in the room below. Our roofers say the cause must be ice-dams from heat-loss, which must have been caused by their removing the old cedar-shakes roof under the old metal roof when they stripped the roof for the new shingles (they added a new plywood base which has a slightly shorter projection than the old metal roof had, new Tyvak "breathable" sheeting, and new wood framing to mount the shingles on). They say the new roof isn’t leaking, but the ice-dams are making water back up and then come inside the walls of the house.
    So they say the answer is more insulation everywhere, but we’re sceptical, since we haven’t changed anything else about our living habits and we’ve never had the problem before. Most of the third-story is plaster-finished living space from a century ago so insulation would be hard to place , and we don’t usually even have any heat on in the third storey or in the second-storey room with the bad leak into the window frame (we do have heat on in a nearby room under the very same slope of roof, but it has not had a problem).
    At present we’re just trying to get through the winter by having the lower few feet of snow shovelled off our new roof soon after a storm; this reduces the amount of water but does not stop it. We have tried to find roofing experts, engineers, etc. without luck to advise us on the problem, since we paid a great deal for this “Cadillac” 50-year plus roof and do not want to spend another winter terrified every time it snows lightly. We are so worried that we are seriously thinking of going to all the expense of having the whole new roof ripped off and replaced by standing seam again, which might dump snow on the nearby sidewalk, but might allow us some peace of mind. We can’t afford to do this, but neither can we afford to have our house rot around us.
    Has anyone else encountered this problem, that when you put a new but similar roof on you changed the environment of your old house so that the old ventilation was no longer adequate? Would just taking off the last few rows of metal shingles and extending the roof projection underneath farther beyond the walls help the front roof-wall area? What would help the valley on a different side?
    We’re at our wits’ end, and would appreciate any suggestions anyone might have.
    61
    Default Re: old house, new metal shingle roof, new water problems
    Unclear if this is your first, second or third (or longer) winter with the new roof, guessing it is your first.
    Unless I missed it, your description seems to be missing at least two important elements, which if missing would begin to explain your troubles.
    1) Ice and water sheild (a self sealing bituminous sheet membrane placed at least at and beyond any ice dam zone, eaves on up beyond the warm transition zone 36"+ beyond (depending on your location), ends, edges, penetrations, and valleys) and 2) proper (and metal compatible) flashing. Roofing felt required (don't know that tyvek is an approved substitute), these are elements in addition to the overall base, still required to properly install flashing and membrane. DECRA specifies proprietary ends, caps, boots, etc. with their systems of stone coated metal shake and shingle panels.
    Very steep description doesn't tell us much, how steep? what is the pitch? certain products shouldn't be used at extreme pitches (too steep or too flat) or if used at or near the extremes, require special installation methods.
    Pull out your contract and hire an independent inspector, the shingle manufacturer might recommend one, possibly even elect to send out one of their own representatives (but acquire your own certified expert as well).
    Act quickly before the statute of limitiations expires regarding an action against your contractor, if required.
    Only after you have assured a dry, properly installed roof would I recommend any insulating efforts, to do now while you have active leaks may be more good money thrown after bad, wet insulation, trapped moisture, mold, rot, etc. wouldn't be a good thing.
    Call for your local DECRA rep in North America at 1-800-795-0776.
    Last edited by unregistered; 02-11-2008 at 11:16 PM. Reason: add phone number for DECRA Roofing Systems
