    Default Repair Drywall Paper rips
    Yeah- I was sloppy.
    While removing old wallpaper I got a little impatient and overly aggressive. While ripping off the wallpaper, some large and small swaths of drywall paper came off that were still adhering to the old wallpaper, leaving a rough lower belly or indentation on the surface of the drywall. There is still some paper on the drywall, but I intend to paint the walls, and I know it will leave a less than pure flat finish.
    Has anyone any ideas the best way to fix this before applying paint?
    980
    Default Re: Repair Drywall Paper rips
    as long as there is still some paper covering they gypsum you can skim over it with drywall compound, then sand it out when dry
