    Unregistered Guest
    Default Antique Pocket Door Adjustment
    100 Year Old Pocket Door Is Dragging. One Side Is Working Well, Need Advice And Images Of Hardware. Walls Are Plastered And I Dont Tear It Apart. Please Help!
    6,053
    Default Re: Antique Pocket Door Adjustment
    Usually the door has rollers on the top that ride in a track. If you look up into the opening at the top you will see the hardware and there should be a screw in the hardware that you use to adjust the hight of the door. It will be on top of the door close to the edge on each side.
    Sep 2007
    I have a pocket door between my living room and bedroom. The door has come off the runners, and recently in trying to fix this myself, I have ended up knocking the wheels\runner from the door to the space between the two walls.
    Got any suggestions of how to delicately remove some of the trim or whatever to get the wheel? or can I get another set somewhere?
    I have attached a picture of the door.
    Click image for larger version.
Name:	pocket door2.jpg
    Thanks.
    Jim
    Chicago, IL
    162
    Pocket doors are removeable. The frame goes in before plaster/drywall, but the door is installed & trimmed out afterwards.
    Remove the door stops. You should then be able to disengage the rollers from the top of the door & remove the door. Fish out the roller from inside the wall, reinsert it into the top track, & reverse the process to reinstall the door.
    HTH
    Dave
