Thread: Wet registers
    Default Wet registers
    We have just upgraded our HVAC system in our 100-year old house in GA. After a few months of running this new system which has three zones, we feel that the house stays very humid and we see mold on our registers and on the carpet around the registers. What gives? The system is adequate (we can drop the temperature quickly if we want to) and we didn't have this problem before. They have changed the size of the return air ducts (I thihnk it is a little smaller now). Could this have caused the issue? By the way, the house is in no way air-tight.
    Thanks for any advise,
    Goshtasp
    Chicago, IL
    162
    Default Re: Wet registers
    Was the size of the AC increased when the system was upgraded? The symptoms that you describe point to an improperly sized (too large) unit. It is cooling the house too rapidly, not running long enough to dehumidify the air.
    HTH
    Dave
