    Default Toilet Troubleshooting
    I need some help diagnosing my toilet trouble. I recently replaced my flapper and was adjusting the tank level. Now my toilet only flushes every other time. when I flush it just fills the bowl up but nothing goes down. The next time I flush everything goes down normal. I have tried adjusting the tank level and the length of time of the flapper being open, but that doesnt seem to work. Do I have a partial blockage in the venting or drain, or something else? Thanks for the help.
    Memphis, not Egypt
    183
    Default Re: Toilet Troubleshooting
    The Fluidmaster is a really good retrofit. Believe it or not I find the old lift wire set type very reliable as well and the ball change is as inexpensive as a flapper reblacement. These are still avaliable by Wolverine Brass. If you are on a well then i do not recommend any brass parts.
