Results 1 to 10 of 15
    Dec 2009
    5
    Question waterheater elements
    i have an AOSmith PermaglasII Conservationist modelFSE52 series820 waterheater.upper element is 1500w and lower one is 1000w.the heater cannot keep up w/ one shower.can i change the elements to 4500w each to increase hot water supply?will tank itself be ok? 240v wired.
    Dec 2009
    5
    Default Re: waterheater elements
    uh...btw, didn't realize i was posting on the joke board.nothing funny about a cold shower when it's your own...or the wifes'.
    Feb 2009
    693
    I'd first make sure both elements are working properly.
    I'd bet the heater is fed with #10 cu wire. If you change the elements out to 4500's you will draw 37.5 amps if both are burning and # 10 is only good for 30 amps.
    A cheap trick would change the lower element out to 1500w.
    Edit: Women tend to be problematic on more than one level...... You may want to give that consideration as well.
    8,046
    Quote Originally Posted by NEC View Post
    For those of us who aren't good with math, if woman A starts talking at 9:15, and woman B starts talking at 9:20, tell how long will it be before the statement you made is wrong?
    Ok, seriously now, where would two 1500 watt elements put the amps?
    6,047
    First of all only one element at a time is every on in a properly functioning WH.
    You would need to check the thermostatic control to see if it is rated at at least 19 amps or 4500 watts or more. Although it will heat the water faster it won't add significantly to the amount of time it takes to run out of hot water.
    If that is a 50 gal tank you should have more than enough hot water for a 10 min shower and most showers are much less than that.
    You could have other problems. One, the tank my be installed backward, that is the cold is on the hot side and the hot on the cold side. Another problem that can cause this is a broken of missing dip tube in the water heater.
    Feb 2009
    693
    ??? Jack may have hit it on the dip tude thing....... How is your dip tude? Could make all the difference in the world.
    Feb 2009
    693
    Not true on most electric water heaters, Jack.
    If the WH is fed with a 30A 240v circuit the elements could be changed to 3000 watt elements and still not exceed 125%.
    Dec 2009
    5
    Question Re: waterheater elements
    hi all.thanks for the advice.everything mentioned (wire,crossed pipes,and such)check out ok.i did not check anode rod though.seems like as good a place to start.how does it affect the amount of hot water in storage?
    Feb 2009
    693
    Quote Originally Posted by jmartin View Post
    Friend, A 1000w lower element may save a ton of cash but will give you warm water about every day # 3.
    Dec 2009
    5
    lol! yeah,seems about right.it is a "Conservationist" model.so is 3000w the max i should go?
