Results 1 to 10 of 14
    35
    Unhappy What is the best insulation product to deter bugs
    I need to insulate our garage before setting up a work shop, at present there is no insulation so its all ready to go. I need to know what is the best insulation to use that would deter a possible invasion from the carpenter ants in the area. They invaded once 2 years ago, but with no insulation it wasn't a problem to get rid of the little @#*. Sooo, what is a good product to use??? Fiber glass they use as a highway, foam will give them a nice home - what other options are out there???
    Thanks so much, all past info has been greatly appreciated and acted on. Very sincerely Normwantabe
    61
    Default Re: What is the best insulation product to deter bugs
    first get rid of the moisture dry things out and prevent further accumulations in the wood.
    treat area with shell-guard all surfaces assure deep penetration.
    use borate treated insulation make sure you make provisions to keep it dry.
    use no spray foam or rigid foam.
    the recycled blue denim batts are borate treated.
    you have more than one post on this subject.
    http://advice.thisoldhouse.com/showthread.php?t=3211
    13
    Cellulose insulation is borate treated.
    You can also purchase a borate solution to spray around before you insulate (which both deters insects and inhibits rot and fungus). Brand names include TimBor and BoraCare.
    As already mentioned you want to eliminate moisture issues before you close up the wall.
    980
    maybe I'm missing something but I don't see anywhere where he says he has a moisture problem
    13
    Eh. The eyes were playing tricks on me.
    Still, it's good advice in general to solve moisture problems
    The deep South
    459
    Quote Originally Posted by unregistered View Post
    " She who must be obeyed " has spoken . Consider yourself scolded .
    13
    Quote Originally Posted by djohns View Post
    You know, a couple of times over the last few days I'll go to the TOH front page, click on a question they've highlighted on the front page, and I'll get a "thread not found" message.
    Are they deleting threads spotlighted on the front page?
    35
    Love you guys
    I don't believe there is moisture problem (the base framing all looks dry), the little buggers climbed up to the second floor of the detached garage and made a home in the insulation of an unused garage door panel (there was no moisture/wet areas in the second floor if anything its blazing hot in the summer and freezing in the winter) the satellite community loved it. When the previous owners built the garage they didn't but down a moisture barrier between the cement and framing. It looks like they put down some fibreglass insulation as a barrier. Should this be addressed? How to retrofix before putting the insulation in and dry walling?????
    You don't have to be a guy to be a Normwantabe
    980
    Quote Originally Posted by normwantabe View Post
    Love you guys
    sorry I did jump to conclusions on that one.
    13
    I don't know if your particular situation calls for a retrofit but in general you don't want to have wood directly in contact with- on or below- grade concrete. The best practice is to use a sill gasket beneath the bottom plate in order to break the capillary action between the concrete and wood.
