    Question Air bubbles in toilets
    I have two toilets in my house that are back to back. The problem is that I have air bubbles in them sometimes and water comes up to the rim sometimes and sometimes the water is draws it self down. How can I fix this? I am on a septic tank.
    Sand Springs, OK
    467
    Default Re: Air bubbles in toilets
    I would suspect that your drain to the septic tank needs to be cleaned out.
    My toilets do this when the roots get to thick between the clean out and the house.
    Debby in Oklahoma
