    Default Rubber Flooring?
    Where can I find the Rubber flooring that was used in the basement of the Newton Project? Was it easy to put down or should I have professional install it?
    Default Re: Rubber Flooring?
    in the exercise room? anywhere! big boxes have it, as do most flooring showrooms.
    yes it is very easy to install, it isn't permanent. you can abut it to base, install base overtop or cut it short like a carpet. it puts together like a jigsaw puzzle and you can trim the edges/tabs off.
