    Default removing paint from plaster walls ??????
    I'm looking for a type of pint stripper that I can use to remove 4-5 layers of paint off my old plaster walls
    if you can help that would be great
    sg
    Default Re: removing paint from plaster walls ??????
    There's actually a feature on this site that describes a stripper made by Removall. For this application you would need Removall 220. It will do a beautiful job!
    Michele in Vancouver
    Omaha, Neb.
    26
    Also check out Peel Away products. Make sure to neutralize as instructed after you have stripped each area. Otherwise, the paint may bubble off later.
