    Default Easy replacement for eyeball high hats
    Is there an easy solution to replacing the large eye-ball recessed lights without having to open the ceiling and replace the cans? Even if I could replace it with the smaller eye-ball, I'd be happy!
    Denver, CO
    666
    Default Re: Easy replacement for eyeball high hats
    It would help to know what brand and part # your cans are.Barring that information cans are basically sized by measuring across the opening, 4”, 6”, 7” and so on.
    “Most” residential housings can be retrofitted with another manufacturers trim. In other words , You can put a Capri trim on a Halo can as long as it is sized to cover the can opening in the ceiling.
    The link will take you to Cooper/Halo’s site and you can go through pages and pages of trims.
    http://www.haloltg.com/common/brands...lectors&page=1
