    Fredericksburg, Virginia, USA
    Question Basement floor & concrete dust
    3 months ago, we moved into a new house with an unfinished concrete basement. The concrete continues to shed excess dust. We want an inexpensive and environmentally safe way to control the dust using paint or sealers. Yet, directions suggest etching first using an acid wash. If the floor is washed and dry, does it need etching? If so, is there another way besides using acid? SBT
    Central Kentucky
    Default Re: Basement floor & concrete dust
    I would recommend using tri-sodium-phosphate (TSP) from the local home improvement store, it mixes with water. Just follow the directions. After that has dried for at least four hours you can put on a concrete sealer, Thompsons makes a great product, like Thompsons Water Seal for masonary and concrete. It goes on very easily with a short nap paint roller. Hope this helps.
    Practice Good Karma
    Jan 2015
    28
    Concrete dusting is a phenomenon with concrete and it is curable. Sealing is one possibility. The other and more common solution is to use a concrete "densifier". This is a water based solution applied to concrete with a common sprayer and worked in with a broom. The most common are usually sodium silicate or potassium silicate. They are available at almost any concrete supply house. If not, just do a search ****** for "concrete densifier" or even "warehouse sealer." The later is because it is pretty standard to prevent dusting in large spaces due to health reasons of concrete dust. From there you can still seal, paint or finish however you like.
