    Default Cold water on sink faucet has no pressure
    The cold water on my bathroom faucet has low pressure when I turn it on. The hot water is fine. I have taken apart the faucet handle and supply line to and check for a blockage, cleaned the aerator. This had not helped. Any suggestions?
    612
    Default Re: Cold water on sink faucet has no pressure
    Do you have an angle stop valve under the sink and did you check that for blockage?
    I live in a 8 unit condo building and can't turn my water off and check that without turning it off to the entire building. I disconnected the hot and cold supply lines from the faucet though and just ran water into a bucket and didn't notice a difference between the two in water pressure.
