    Default low hot water pressure in tub and shower
    I have good cold and hot water pressure throughout the house. I have good cold water pressure in my tub and shower but I have low hot water pressure in my tub and shower what can be wrong?
    Default Re: low hot water pressure in tub and shower
    check the cartrige in the valve if its a moen they will send you a new one for free or any parts if not pull it apart check o rings .
    Quote Originally Posted by Infraredsurvey.com View Post
    Im new to home improvements. When you say "check the cartridge in the valve," What cartridge do you mean and what valve? Do you mean the knob that moves left to right (hot water left cold water right)?
    Yes the handel has a set screw under the plastic cap with the logo or underneath.Before you do anything turn the water off at the main. If in dought get a book or google the maker of the valve.yes the valve that moves left to right
    Go for it arh arh arh
