Results 1 to 10 of 16
    Pacific Northwest
    Default Cleaning the grunge from around light switches
    All of my light switches (the switches, not the plates) have have an accumulation of grunge around them. It's going to take some degreaser, like 409, a toothbrush, and toothpicks to dissolve and pick this stuff out.
    I'm concerned about spraying a liquid into a hot electrical outlet. Is it sufficient to turn off the power to the switches while I'm working on them, and perhaps leave it off until I'm sure everything is dry again?
    Anyone have a better solution - short of removing or replacing the switches? (I'm not an electrician, nor have I played one on tv <wink>)
    Thanks!
    Gwyn
    980
    Default Re: Cleaning the grunge from around light switches
    I would simply turn off the elec. and try using a vacum first. but I think I would be more concerned over why you were getting any "grunge" in a closed box.
    The deep South
    459
    Do you have a Central Heating and Air system ? You might be pulling return air back through the walls .
    Or , it could just be years of grunge from dirty hands ( kids ? ) .
    Denver, CO
    666
    Sure,
    I canít stand grungy receptacles and switches either and use the cleaner/tooth brush as needed.
    Iíd turn the circuit off to be safe, scrub away, let dry and turn the circuit back on.
    612
    Quote Originally Posted by kentvw View Post
    Sure,
    Doesn't your toothbrush taste funny after that????
    Pacific Northwest
    No, dusting and vacuuming won't work. This is gunk that's accumulated on and around the switch itself (the movable part). It's from years of dirty hands and ambient dust accumulating in a humid environment. It's not dust inside the box.
    Gwyn
    Denver, CO
    666
    Quote Originally Posted by Gwynm View Post
    Gwyn
    I knew what you meant, Gwyn.............. You know, after a while, all that Granite dust........... Well, it takes a toll on faculties.
    980
    I used to clean it out with a little alcohol every once in a while. now I use 409 and a tooth brush.
    Pacific Northwest
    Thanks for the input, guys! A-scrubbing I will go!
    Gwyn
    Denver, CO
    666
    Spic-n-span werks good too.
