Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 37
  1. #11
    980
    Default Re: Water Bill Doubled
    The first thing to do is check the meter. I got a $300 electric bill one month, usual use is $70, because the meter reader transposed two numbers. That's hard on an old mans heart.
    jack your tooo funny
  2. #12
    Denver, CO
    666
    Quote Originally Posted by havanagranite View Post
    sir kent you must have made an error for we know the gov't doesn't make mistakes
    Meaning?
    Whadda I miss?
    Extra 7000 per month. 30 days*24 hours = 720hrs.
    7000/720= 9.722222222222222222222222222222222222222222222222 222
    Last edited by kentvw; 01-17-2008 at 04:41 PM. Reason: Bad, bad use of little marky thingys other than letters which reside on my keyboard.
  3. #13
    Building on the "read the meter" thing.
    Has there been any work done in the yard near where the supply line comes in from the street to the house? (I've got a story about that one ... )
    Go read your meter and note the number, wait one hour and go recheck the meter and note the number. Now, turn off the water at the house, wait an hour and recheck the meter. This will tell you if the problem is in the house, between the house and the street, or the water department needed a raise this month.
  4. #14
    Denver, CO
    666
    Mileage may vary depending on where the meter is located. At the street or at the house.
  5. #15
    Most meters will have a flow indicator ... in the case of the mechanical type there may be a small white star shaped device that spins when there is flow through through the meter.
    Depending where the meter is located will also help determining where there may flow when there shouldn't be.
    If the meter is located in the home and if there were a leak between the street and the house this wouldn't register through the meter.
    If the meter is outside then there could be a leak between the meter and the house.
    Yeah, I'd say there is a problem but it could be a combination of things.
    sorry kent ... I didn't catch what you were meaning.
  6. #16
    980
    Quote Originally Posted by kentvw View Post
    Meaning?
    Whadda I miss?
    Last edited by kentvw : Today at 04:41 PM. Reason: Bad, bad use of little marky thingys other than letters which reside on my keyboard.
    I wasn't speaking of your calculations. I was saying in regards to your being billed on averages
  7. #17
    Denver, CO
    666
    Oh................
  8. #18
    Why do you guys have to get so technical? You mean everyones house isn't the same as mine?
    I wonder if there's a water softener that might be backwashing itself too frequently, or is stuck on that cycle.
  9. #19
    980
    dw taught us
  10. #20
    6,103
    I can't beleive it took that long for one of us to think of that.
